Please Support Rix Racing
Street Build 1998 GSX resurrection
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Street
3" turbo back exhaust, Ebay recirculating (new)Precision 60-1 turbo(? trim), external WG(? mm),Walbro 255 fuel pump, RC 850 injectors
Mods-Engine
6 bolt swap
2G JE 8:5-1 pistons 0.020
machined rods for pistons
ARP rod bolts
polished crank
balance shaft removal kit
ARP head studs
Fel Pro HG
Mods-EMS & Logging
FP 4” intake w factory MAF
All new black 2.5” FMIC piping
SAFC II
Autometer Ultra Lite AFR/Boost/EGT gauges
Tactrix Openport 2.0
EcuFlash For tuning
Evoscan for data logging
Still have the Translator and GM Maf but not using
Mods-Drivetrain
ACT lightened flywheel
ACT 2600
New front rack pinion, sway bar shocks struts.
Parts Wishlist
Cams, valves/seals, springs/retainers, larger TB, speed density, some engine management upgrades, bigger/better turbo, larger fuel pump, larger injectors, forged pistons, rods, larger intercooler and piping and last but not least; more knowledge
Background
Bought the car from a friend who drove the car 2-300 miles after the 6 bolt swap. I helped with the majority of the mods after the swap. The car sat in his garage for roughly 10 years. My friend recently found the receipts for the engine build and I edited the mods section. I'm slowly fixing minor issues that arise after the car sat for soo long. I'm hoping to "resurrect" the car to the 400+ hp goals that we set for it a decade ago. Engine management and all the sensors needed to achieve that are things I'm focused on now. After thatI'll be working towards getting the fuel delivery upgrades.
  • Like
Reactions: 609DSM
FAQGSX222
Comments
More in 2G DSM
Share this Vehicle
