Street Build 1999 GST
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
50-trim
Build Type
  1. Street
NGR Type-S blow off valve//Punishment Racing Front Mount Intercooler//Poly motor mounts//FP race exhaust manifold//Evo lll intake manifold//Holset H1C with bep housing//Tial MVS 38mm external wastegate//Warlbro 255lph hp fuel pump w/ rewire kit//Punishment racing o2 housing//Punishment racing 3'' downpipe//Punishment racing aluminum radiator with 2 slim fans and shroud//Greddy oil catch can//Rebuilt 1g Throttlebody//FP 4'' intake//Fuel lab AFPR//Fuel lab fuel filter
Mods-Engine
Manley H-beam rods//Platinum series Manley pistons(9:1)//OEM Mains//STM BSE Kit//ACL rod, thrust and main bearings//ARP headstuds//EPN SS valves//EPN revised lifters//EPN bronze valve guides//Evo lX springs and retainers//Cometic MLS headgasket//Ferrea valve stem seals//Fidanza cam gears//Delta cams H272
Mods-EMS & Logging
Hallman Pro RX Manual boost controller//Apex integration turbo timer//Reflashed ECU//AEM boost gauge//AEM UEGO A/F ratio gauge//AEM oil pressure gauge
Mods-Drivetrain
JNZ Tuning shift kit//B&M Short Shifter//Brass Shifter Cable Bushings//Apc shift knob//Act 2600 with street disk//SS master to slave line//Act streetlite flywheel
Brake Labs Drilled & Slotted Rotors with Ceramic Pads//Rear camber fix//Tokico HP strut/spring kit.
Aproductions
More in 2G DSM
Share this Vehicle
