- Ownership Status
- No Longer Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- Evap + EGR delete
Big 16G turbo
Hallman Pro boost controller
3" fabricated catless exhaust
SS braided turbo oil lines
3" intake pipe w/ Vibrant air filter
Modded intake side headlight cover
Rewired AEM 340 LPH fuel pump
PTE 680CC injectors
AEM fuel pressure regulator
- Mods-EMS & Logging
- Autometer 30 PSI boost/vacuum gauge
Innovate LC2 wideband
ECMLink V3
GM 3 bar MAP sensor
GM IAT sensor
- Mods-Handling
- KYB AGX struts with Megan Racing lowering springs
Ingall front camber adjustment bolts
Powerstop Z26 brake pads and rotors
Megan Racing rear strut tower bar
Ebay front strut tower bar
Continental ExtremeContact DWS-06 tires
Polyurethane rear sway bar bushings
- Parts Wishlist
- Evo 3 16G turbo, silicone rad hoses, aluminum radiator, FMIC, 1200CC high-Z injectors, -8AN fuel feed line, thicker rear sway bar, polyurethane bushings, SS braided brake lines, dual piston front brakes, 4 bolt rear end swap, wheels
