Please Support Kiggly Racing
1990 Talon Tsi - up through 2015
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
14b
Build Type
  1. Street
Megan downpipe, custom test pipe (Andre at Pina Motorsports), Megan 3" catback exhaust... 850cc FIC injectors... K&N 3320 air filter on 3" GM MAF on Dejon custom short "P" style intake to stock 14b... Walbro 255 LphHP in-tank ... Fuelab 515 fuel pressure regulator... Rubber fuel hoses are 5/16" Goodyear J30R9 (great hose) and -6 Russell Pro-Classic. Having some trouble with the Pro-Classic fittings... Koyo radiator w Gates Racing hoses... TurboXS type H blow-off valve... HKS EVC model 1 boost controller (1987 - now that's old school!)... new non-cruise throttle cable from Mitsu obsolete parts warehouse!... NGK plug wires (blue)... HALOTRON fire extinguisher...
Mods-EMS & Logging
DSMchips 1994 ecu modded to full 1990 plug n play, programmed to read 2g MAS hz, and relocated to passenger footwell... silver box ECU+ (sweetest software I've ever seen!)... ECU+ translates GM MAF to 2g MAS Hz.... Autometer Tach....Honeywell # MLH100PGB06A fuel pressure sensor and Innovate LC-1 wideband basic kit (no gauge) to ECU+ logger .... AEM # 30-2131-50 brass 3.5 bar MAP sensor kit to logger ....
Mods-Drivetrain
Lucas English '91 tranny, welded center diff, 4-bolt LSD rear end from '93, ACT 2600 w street disk, ACT streetlite flywheel, rebuilt driveshaft. Installs done by PINA Motorsports in Kent Washington.
H&R springs, KYB AGX struts, brembo sport rotors w stock calipers, Enkei 18" GF1 wheels, Installs done by Alignments Plus in Bellevue WA
  • DSCN1745  engine bay, final configuration of original engine, Sept 2015.JPG
  • Talon with 5-16ths hose and #13 fuel injection hose clamps replacing stock hose at tank.JPG
  • Talon in 2009 with new 5-16ths fuel hose from tank to hard line under car.JPG
We're on Boost
More in 1G DSM
More from We're on Boost
Share this Vehicle
