Please Support Kiggly Racing
Drag Race Build Ready for 9s
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
HX40
Drivetrain
AWD
Build Type
  1. Drag Race
Archerfab 3" downpipe with archerfab 3" turn down
Tial 44mm external wastegate
Boostin performance/KDN shifter
Tial bov
Innovate lc2 wideband
Holset hx40 6 blade with t3 exhaust housing
Archerfab exhaust manifold
Link controlled boost solenoid
Magnus intake manifold
Bosch 68mm DBW throttle body
FIC fuel rail
Real street -10 catch can
FF Valve cover
Fp 4" intake
Mishimoto radiator with 2 12" slim fans
ETS 4" fmic
Fluiddamper crank pulley
Mods-Engine
Wiseco extreme duty hd forged Pistons 8.5:1 (.020 over)
Manley turbo tuff I beam steel rods
Ferrea 6000 series standard size intake and exhaust valves
Ferrea valve locks
Top line revised lifters
Kelford 272 cams
Torque plate bore and hone.020 over
Align hone mains
Balanced rotating assembly
King xp tri metal rods and main bearings
Arp main studs
Gsc race balance shaft
Mitsu multi layer metal head gasket
Stage 1 port of the head
Arp L19 head studs
FIC 2150s
Magnafuel 750 external fuel pump rewire with #8 wire & dual relay
-8 line feed and return
Fuel lab AFPR set to 43.5psi
Vamos bolt on fuel cell with 2 8an to a Y -12 to pump
Mods-EMS & Logging
Haltech elite 1500
Sd conversation
Gm 4 bar map sensor
Mods-Drivetrain
Ppg dog box with center spool and quiafe front lsd
Boostin performance billet bearing plate
Magnus 1-2 shift fork
Quarter master 8 leg twin disk
Competion forged clutch fork
Drive shaft shop aluminum driveshaft 3”
Vamos driveshaft loops
Boostin performance 300m output shaft
Magnus Billet bearing cover for transfer case
Boostin performance 300m transfer case
Boostin performance billet center section for t case
Frontline fab billet rear dif cover
Strickly performance rear axles
Megan racing 32 way coilovers
Rm racing rear sway bar
STM rear camber bolts
Meagan racing rear upper sway bar
Enkei rpf1 17x8+35 wrapped in bf Goodrich g force sport comp-2 235/45/17
Wilwood big front brakes
Seibon carbon fiber hood with aero catch
Carbonetic carbon fiber doors
Carbonetic carbon fiber sunroof delete
Special carbon fiber fenders
Carbon fiber hatch with lexan
10 point custom made chromoly roll cage
Volk solid subframe bushings and solid dif bushings
1/8 Mile E/T
6.906
1/8 Mile MPH
111.55
Timeslip Details
16" Hoosier qtp
Island drag way great Meadows new jersey
E80 at 35-37psi of boost with no nitrous 5 speed car
Dyno HP
718 whp
582.2 lb/ft
Dyno Type
DynoJet
Jacolu3
Comments
3
Rating
5.00 star(s) 3 ratings
More in 2G DSM
Share this Vehicle
